FF85wk In A PVC Enclosure
I would say it is a bad idea, I have tried it. PVC case are only good for woofers. They cancel out the pressure because of symmetry, but a high frequencies the PVC case will just vibrate. Unless you have 1" Thick PVC pipe...You can try damp the cabinet with bitumen pads.
