I'll be curious to see how the smps I have here goes.
What is the value of the output caps on your SMPS?
Cheers
I'm afraid can't tell you for a week as I'm traveling interstate. I'm not sure it matters though...
If it was that simple id load the output with caps and be done with it, but a smps works differently. The documentation thread has a good post about changes needed to the amp to accommodate a smps.
Groupsbuy will be closed at January 15 payments can be done 1964Roovers@gmail.com
Update the spreadsheet https://docs.google.com/spreadsheet...UzV6NElOOTdqYmY0OENaaFBVLWc&usp=sharing#gid=0
Hello meanman1964,
I am back from my holiday.
I have sent the payment per Paypal and updated the spreadsheet.
Thank you very much for the group buy!
Marcell
Marcell
I'm looking forward to the build... As soon as I get through moving house! The case I ordered is apparently at the local Post Office, the SMPS arrived earlier, and I should have all the other bits and bobs already.
...All I need now are the boards and parts. And those pesky 0R15 smd filter resistors...
Would be interesting if you could post your particular BOM later when everything is sourced. I too plan on using an SMPS, and if you are building according to Paul's instructions, i believe you only need 2 pieces 0R15's per channel instead of four, but i could be wrong(it was early in the morning).
What size caps do you plan on putting for the first and the second PSU caps? I'm going to try with 470uF as the first, and probably a wee bit larger as the second one, i guess it will be trial & error to see what the SMPS can cope with.
There is a wealth of information about particular component choices buried deep within the original threads, i feel like digging through it all again and collecting the pertinent information in one place, maybe Fetzilla deserves a Wiki article? 🙂
rgds,
Kristian
I have an order at Mouser and yes also those 0R15 SMD resistors shall I include them in the parcel?
Might the 0R15 be included in the group buy?
Cheers
I'd very much appreciate the smd resistors being included since it will save much time and money for me. As i wrote in the PM, i'm in for 8-10 pcs, so i can burn some without worrying.
Thanks!
Kristian
Thanks!
Kristian
Do the 0r15 need to be smd? I think I have through hole on order.
Thanks, Terry
They need to be as flat as possible cause they come under the board.Maybe you can use the MPC resistors.Just let me know if you need some
Cheers
Normaly not but I've the same for my Naksa70 ordered I always can increase the amount
@meanman That's a very kind offer! My original plan was to parallel a couple of 0r47 thru holes (there's a pic on one of the threads somewhere of someone who did the same) but it's not a very elegant solution. If you could include the resistors in the order that would be great, assuming they are a reasonable cost. I had a quick look last night and the recommended part was $7AUD at mouser per unit! At that price I'll happily improvise my own solution...
In short, if the resistors are a fair price I would very much appreciate it if you include them in my order meanman. Thanks!
@yakuza I'm not sure my final BOM will provide much insight! I tend towards the view that I'm unlikely to pick the difference between passive part types in the end sound, and I sleep well enough at night not worrying about not using boutique parts... However a wiki entry is likely to be quite useful to most!
Right, i forgot those resistors were some pricey bastards. Maybe getting extra just for safety is a bit over the top.
@yacuza I'm not sure my final BOM will provide much insight! I tend towards the view that I'm unlikely to pick the difference between passive part types in the end sound, and I sleep well enough at night not worrying about not using boutique parts... However a wiki entry is likely to be quite useful to most!
Yeah it seems building the Fetzilla with just standard run-of-the-mill parts yields quite good results. This also rings true with the old adage that implementation, layout and construction account for 90%, component selection(within reason) the other 10%.
The SMD 0R15 resistors cost between 2 and 3 AUD.The same as I use in my previous groupsbuy.Just build your FetZilla with good parts not exotic ones,I did use Panasonic FC
The price depends on how many I buy 1 to 25 = 1,10 Euro without VAT from 25 pieces 0,88 Euro , 100 pieces 0,77 Euro
Patrick, I would very much appreciate it if you could supply the proper SMT resistors for my two boards.
What is the part number for the SMD 0R15 resistors? I was going by the BOM in Swordfishy and the part number is a through hole part.
Thanks, Terry
Thanks, Terry
- Group Buys
- FetZilla groupsbuy 5
