FetZilla groupsbuy 5
Just received my SMPS - happily it may well be a slightly higher voltage than the expected +-25V(~30V unloaded, 28V on the silkscreen, yet to test under load) appears to have a +5 output also (the header isn't there though, so I don't know if it has any load capacity and I see a pin for the +-15V supply marked 'mute'. Could be useful!
Anyway I mention this on this thread as it seems relevant to folk doing a smps build on this GB, but I don't want to clutter the buy thread. MM (in particular, but anyone else as well) what would you prefer?
I want to warn you that if you order your SMPS directly from Connexelectronics, expect a long wait. I paid for mine on 12/12/13. They didn't ship until 12/16 and it didn't leave the sort facility until 12/28. No telling when it will get here in California. The other issue is that they make it look like as if you are buying a 110V supply but then send you an email telling you that it is actually set up for 220V. Seems I will have to convert it once I receive it. HiFimeDIY.com carries the 110V units in stock and shipping is half what Connex charges. If you live in the US it is a no-brainer.
You need 35Vdc for the FetZilla or are you planning to run it at lower voltage?
Lower voltage and higher bias - my speakers are higher sensitivity so less power is fine. The heatsinks I'll be using are 275*90*25 (L x H x W) so should be more than adequate to run a higher bias. Means I can get away with a 200W power supply too I hope!
I think a few of us would like to hear of your SMPS experience
Though its probably best in a Fetzilla thread on . . building - I suggest re-posting there
Though I don't know - which thread covers Fetzilla building?
Cheers
Did you get the same one as Patrick? Or. . from?
I'm also in Oz - what is the cost inc post?
Cheers
Plan for my build
Hi otto88,
I've a different smps here than still4given - i got it here at aliexpress for ~$50. I just tested it and put a couple of amps through a dummy load - it was steady at about +-24V. It has a lower current +-15V supply on the board also allegedly good for 5W so I'm considering a pre to put on it, and make an integrated amp.
The enclosure is on order ($64.90 and I haven't seen it yet) from here I've bought from this suppler before and was happy, so I'm looking forward to seeing this unit. I reckon it'll be a tight squeeze to fit it all in, but they always seem to end up that way... 🙂
I'll bias at a planned .75A - dissipation at that point should be about 40W per channel (48V from +ve to -ve times .75). At an estimated .5C/W for the heatsink (seat o the pants number) that gets me a ~20C rise, and summer here hits over 40C, so that gets a final temp of 60C for the amp. I've been a bit conservative there so hopefully I'll be all good (if not I'll drop the bias back down!). The reason for the higher bias is that I need little power for my main speakers (94dBm/W (1m)) so with a higher bias I figure I'll be sitting in the Class A section of the amps operation all the time, so why not?
Anyway, that's the plan. Anyone got a recommendation for a pre to match that draws less than 5W?
Hi AS
I'll check the links
I'll probably also set bias at c 0.75
A mate got an F5 kit from this place and was happy
Here's the best of their 3 preamps:
NE5532 HI FI Stereo Line Preamplifier With Onboard LM317 LM337 DC Regulator KIT | eBay
Are you getting your power trannie from Harbuch?
Does that amp case include the pictured heatsinks!?
I was considering one of these:
Chassis case item
They are slow responding to email, but shipping is fast
(http://www.diyaudio.com/forums/group-buys/154291-pre-poweramp-case-group-buy-2.html#post2703028) Ive bought their once before
I know the - would need vents drilled - but nicely "round cornered" like a large Mac Mini PRAL-47328R (about half way down that webpage) is NT (Taiwanese $) is
$7800 +shipping by EMS to Australia at NT$1700 ie NT 9500, about US$ 330. Crazy I guess, but looks great
The PWAD-A40 used to be about US$ 170
Preliminary test results with one SMPS and two modules.The treble and mids are more open and nice to listen. The bass is changed seems to be reduced.The reason I think is the value of the output caps of the SMPS 4000µF(for the two channels) against conventional psu with 18800µF(one channel).
Can tell you mre when I recieve my second SMPS
@otto I'll check out those links, thanks very much. To your questions - no trannie, that's what the smps is for, and should take up a lot less space! The case does include the heatsinks, so it's cheaper than buying a rack case and a pair of heatsinks here in oz. What are you planning on using as heatsinks on those cases you're looking at? I do like the curved corner one... And finally the board is 150mm*80mm.
