FETs stage output Rockford Fosgate T10001BD
What fets does it have in the output stage? rockford fosgate T10001bd with mixed fets on output stage
and someone have the schematic of this version?
I 'carefully' use a pressure washer after spraying the board down with some sort of cleaner (409, Fantastic...).
The switches in these amps are dodgy under the best conditions. If you clean the board and get the switches wet, be sure to flush them thoroughly with some sort of contact cleaner. The pots are harder to flush so you may want to wrap them to prevent them getting wet.
If you do this, make absolutely sure that it's completely dry before powering it up again.
