C'mon leadbelly, there's plenty of room to just answer the question the guy is asking, which seems to boil down to "is there a higher performance option than my 2134 for this application".
Doesn't even need to be higher performance. Just needs to be FET, a bit cleaner and stronger than a TLO72, and not quite as hard-sounding as a 2134.
> TL07x ....oscillate on 6' cables ...despite 50 Ohm isolating series R
The series R should be "not small" compared to opamp open-loop output impedance. The '07x amps have a whopping ~~200 Ohms here, so you need at least 300r between the pin and the outside world (even a small 6-foot world). '5532 is under 100r (maybe near 30r) so 100r in series leaves plenty of output for the NFB to do its thing.
