ferrite-cored output inductor on a class AB amp?
OK. I had lost track of which inductor we were talking about. 10A peak would be 400W into 8R.
The inductor in post #11 was put forward as higher rated than was being discussed earlier. Personally I would use the normal aircore on resistor and avoid these issues with some careful layout.
Ferrite cores have additional downsides, relatively expensive and fragile - have heard speaker crossover inductors making cracking noises.
(the output inductor) should be located away from the amplifier, especially the input and away from the chassis metal.
That makes the best place somewhere in the cable between the amplifier and the output terminals.
i have some ferrite beads (i/d 10mm o/d14mm L 19mm)
when a wire is passed through it, these add about 1.2uH
do you think placing one on the cable between the amplifier and the output terminals will serve fine as an output inductor?
Since these beads are generally group 4 (NiZn), they will be completely saturated at ~0.3T. With this example, for 1 turn, it means 9.5A. If the amplifier is 250W/4 ohm, it will deliver 7.9Arms, 11.2Apk.
Thus, to simplify, between 9.5A and 11.2A, the inductor will become a piece of wire.
At 5kHz for example, 1.2µH is 37 milliohm, around 1/100th of 4 ohm, which will be switched on and off for 1.7/11.2 of the cycle, ~0.15. The end result will be a distortion a bit under 0.15% at 5kHz and 250W, purely odd order.
These are back of an envelope calculations, but they give a realistic order of magnitude: it could be 0.1% or 0.3%, it doesn't matter: it is not negligible for a modern amplifier.
Note that saturation is not a binary mechanism: first signs will appear well below 0.3T, and there will be a residual inductance above, but distortions will be generated, and they aren't negligible.
If your amp is 25W/8 ohm, and you don't need to achieve ppm levels of THD, it would be fine though
Reactions: minek123
