Fender Deluxe Reverb Silverface, no EQ on one channel
Hi guys.
I just received a Fender Deluxe Reverb (silverface, I guess it's a 65 or 68 original) for fixing the normal channel witch has volume but treble and bass do not work. When turning up the bass control, sound gets thin and weak.
I swapped tube #1 and #2, and result is the same: no EQ on normal channel, tremolo channel works fine with both tubes.
Any idea what might be going on with the normal channel?
I replaced all caps with similar values. 390pF 400V poliester instead of 250pF ceramic, 0.1uF 400V instead of 630V and 0.033uF n600V instead of 0.047uF 630V. Thats what I had on hand. The treble control does work now but the bass control does not. When I turn it ccw, it cuts out the bass frequencies but when turning cw (approx at 2 o'clock), it cuts out again leaving only the treble.
The normal channel now sounds noticeably weaker than the other channel, and it's supposed to sound the same.
Maybe it's because I used slightly different values but I really don't think so.
Any more ideas?
