Fell lens
Hi guys.
My CD Recorder Pioneer stopped working.
After disassembled it, I found that the laser lens rolled into the box.
Obviously fallen during transport.
Is it possible to fix with glue or something more is needed?
Cheers
You should be able to see exactly where it came from and what orientation. This is critical so as not to need to physically adjust the Laser Grating.
I wouldn't use Super-Glue. It has a tendency to make the Lens go 'cloudy'.
Some other Glue should work.
But I cannot stress enough about getting it back in exactly the same orienation as it came from.
P.
I've never seen that happen in all the countless players we used to service. I think it should be OK if get the correct orientation.
A tiny tiny bit of warm epoxy dripped onto the four corners after you have placed the lens and confirmed all is good should be perfect.
