hello guys , i got a simple question
i got a push pull smps running from 12V (car) and the out is -+30V
so i want to put output inductors .....
now the problem is :
output inductors - before or after the filtering caps?
where to take the feedback signal - before or after the inductors?
thanx
thanx
can u explain plz ?
i want to run couple of amps and see what will fit best , so every amp needs a different supply voltage , i dont want to deal with turns ratio ...
anyway, whats wrong with feedback?
if my output voltage is higher then needed and i'll reduce it using feedback so under heavy loads the duty cycle will increase so the output voltage will remain constant .....am i wrong?
