Fe108ES horn recommendations
Hi, I am currently housing my pair of Fostex Fe108ES in a pair of standard sized voigt pipes. While the sound is good, the pipes were only designed to be a temporary home giving me time to finish a set of proper horns. I had intended on building the Fostex recommended design but after following these and other forums for a while there may be other possibly better designs than those recommended by Fostex. If you have any experience listening or building either the Fostex design or another design I would sure appreciate any input, as I would prefer to only build one set of horns.
Thanks for any help you can provide.
I think you should get in contact with this man from you can buy anything from plans to complete speakers from
http://audio-resolution.com/zhorn/
