You know what would be sweet is stick to a 8 inch woofer in the bib and build a simple hyperbolic wave guide for the fe103. I saw one recently and thought what a top use for a fe103. The guy was real happy with it too. Even in a bib the fe103 would be limited output or loudness in anything but a really small room. The bass just swamps the midrange. I have build one once . The needle tqwt.
Hello,
look the Xmax of the driver and the stroke in a BIB,
IMHO you will get dynamic compression in bass and low mid below a half watt.
An alternative would be a double horn, i prefer my KORNETT,
bass down 34 Hz, lowest membran movement.
