FE 166/ 167/ 206/ 207 - 40 watts?
A 40 watt tube amp is underway. I have a big room and when my wife is out like to crank it up and hear it over the house. :cloud9:
Aftyer looking at quite a few options (including for a while three ways):
I want to use one of these four Fostex above a 15" midbass (Lambda, smooth - on axis up to c 2kHz), to cover "only" from a XO point to be trialled, c 500 – 800 Hz and up. ie a 2 way passive with 94 - 95 db sensitivity
Both to be open baffle. The Fostex quite likely EnABLed.
Relieving the bass and lower mid excursions, would all these Fostex handle 40 watts?
Presumably then depending on my distance from the speakers, being capable of c 105 – 107 dB peaks – cleanly?
Fostex spec sheets say the rated watts inputs are:
Rated watts "Music Power"(?)
166 & 167 22 65
206 30 90
207 45 90
Fostex specs are optimistic, however I’d be using them very conservatively.
Sound realistic?
I'm not into amps and watts (yet) but is all a marketing tool. You have a music output, so is about double max or continuos amp output (generally for a few seconds only). Then reduce for RMS. Say Music Power 100W, then look for the one you want that is Rated Input 31W. If you have this max output is fine for me. You can work with lower RMS also (percentage lower than all the peacks).
I normally never look at ratings - though normally use drivers where the driver rating is 3 – 10 * higher than the amp output.
Here they're close:
So the question is about how much you could increase the rating, when most of the bass and lower mids (< 600 Hz) aren't going through?
in 6 months I will be living in a non urban district.
And I don't intend to do this every day! Maybe 2 - 3 times a year. Maybe once a year. But I want the system to be able to handle all situations
You are questioning how many dB are needed:
That is partly personal, and remember I am referring only to peaks, not averages. And "undistorted"
Some folk (GM) want 120 dB. I used to aim for 105 Db peaks, now I aim for 110, to have a littel in reserve.
But my question is about the effect of restricted LF . .
Cheers
if you're looking for something all over the house, why not build several smaller speakers, and set them up in different rooms? you can stream audio over network to independent players in each room, or run the speaker cable from a central amp...
I dont doubt it's VERY loud, up close
But I might be listening 15 m away, as I said it over (or throughout) the house, ie through walls.
So used > 600 Hz, 40 w wouldn't stain the drivers?
I have FE166E's passively crossed at 300 Hz to 2-15" Jamo woofers per side, all OB. I don't find the OB bass 'follows' me through the house that well, and the Fostex start to break up if pushed too hard. They may not break, but they don't sound their best cranked up.
To fill the house with sound, I'd think more about using the Lambda in a box with a horn/waveguide tweeter crossed up around 1500. The Fostex/ob system would be nice at lower volumes (i.e. when your wife is home).
JMO, of course.
Lousymusician,
Thank you! I'd begun to think about using a good HE midwoofer in a box, with a horn/waveguide tweeter crossed up around 1500
And if the Fostex starts to break up even a little at all at higher dB, and as I have a good HE mid-woofer (a BMS) and a good compression driver tweeter – that settles it. I'll mate something else with the Lambda . .
Cheers
