A model for this MOSFET is not available as far as I can see. Onsemi offers nothing as far as I can see.
Is there any way to use the datasheet parameters to create / modify a file that can be used in ltSpice?
Regards, Gerrit
Regards, Gerrit
the reverse capacitance looks a bit different from infineon fet SPW55N80, the rest seems similar, you could give that one a try.
Hi Basreflex,
Thanks, this seems to be close enough to get it working in LTSpice.
Regards, Gerrit
Regards, Gerrit
The spice model is available on the OnSemi website: https://www.onsemi.com/products/dis...19-,Simulation Models,(3),-Name / Description
