Here's what I have. So, I need to put resistors in the board and leave the transistors out?
https://drive.google.com/file/d/0B50P1QWuuYzcR1FTbllmNFdpbm8/edit?usp=sharing
Yes, some of the traces have been pulled out of the board, however I replace them with copper cable if necessary.
I don't have a schematic diagram for this amp. If you clean it up, you should be able to tell where each trace goes.
I think the resistors go to the collectors of the regulator transistors. The emitters of the regulator transistors connect to the op-amps. The bases of the regulator transistors connect to the zener diodes. You can verify these with a multimeter.
- General Interest
- Car Audio
- Faulty MTX 500D
