Does any one have schematics for a kicker IX702? or know much about there design? The output stage uses 1 tip36c and tip35c per channel (two channel amp) and the power supply uses 4 k2312's?.
This amp has been on it's way out for a long time, it would over-heat with a 4-ohm load and no input (RCA disconected), had bad distortion at high levels on some days and none on others even playing the same cd. And now it just sounds bad at any level and i cant seem to find the problem.
Please Help,
Sean McGee
Please Help,
Sean McGee
