I would consider this SB driver:
SB Acoustics :: 6" SB17NBAC35-4
Heard it a week ago, and it plays VERY smooth, open and no problem going down to 30-35 Hz - It was crossed around 2K Hz.
I currently own a pair of SB17MFC35-4 and these have also no issues going to 35 Hz in a 16 Liter cabinet (basreflex)
That's the one I am eyeing. The silver coloured is ugly... I think it should be similar to yours...
Oon
My own personal experience, is you can't get a subwoofer to do midbass work well. It will sound a bit slow..
That is my experience too.
I haven't comes across any that can do midbass.
Mike
Care to share a bit more of the MLTL design for the5 1/4 inch?
Oon.
email me. The design is proprietary, but we do need a few beta builds.
dave
A subwoofer that doesn’t do midbass? Given that midbass is definded as 40-80 Hz i think it would be hard to find one that doesn’t cover this band.
The CSS SDX10 goes up pretty high — into the mid 100s at least, maybe usable into the high 100s.
dave
Seriously? 40Hz.... midbassGiven that midbass is definded as 40-80 Hz....
20-40 Hz — Lower bass
40-80 Hz — Mid bass’Upper bass
80-320 Hz — Lower midrange
320-640 Hz — Midrange
640-1,280 Hz — Midrange
1.25-2.5 kHz — Upper midrange
2.5–5 kHz — Lower treble
5-10 kHz — Mid Treble
10-20 kHz — Upper Treble
3 octaves of bass, 4 of midrange, 3 of treble
dave
dave
Gotta disagree with 40 Hz being mid-bass.
I an just reiterating the definition. A lot of people call even lower midrange, midbass, but that is wrong.
dave
From Troelsgravesen's site
Definition of frequency ranges.
Yep it's throw away as us old farts can't hear above 10k.
Whenever i thought of this, then i get to listen to 100khz ribbon, and i can hear/see why it is beneficial to have highest freq response available. Even though i may or may not like the sound signature of it.
Interesting chart. I particularly like the lower bottom of the chart where it shows, human hearing emotions vs frequency, such as warmth, punch etc. I thought warm would be a bit higher is frequency though.An externally hosted image should be here but it was not working when we last tested it.
Interactive Frequency Chart - Independent Recording Network
I can't hear a test signal above 10k but know if it is there in music. If it is missing, you can pick the difference.
I think what Michael meant and I agree with him is subwoofer do midbass poorly especially above a 100Hz. It's like having a normal monitor speaker that goes down to 50Hz and you decide to cross at 200Hz to a huge 15 inch subwoofer with a high pass for your speaker.A subwoofer that doesn’t do midbass? Given that midbass is definded as 40-80 Hz i think it would be hard to find one that doesn’t cover this band.
dave
The bass will sound a bit slow and there would be a lack of punch and definition. I attribute it to the heavy cones of the subwoofer... A 15 inch subwoofer cone can be almost 200grams of Mms. Whereas a good 4 inch is only about 4gms... The motor force of the 15inch is a bit higher but not by much.
Too much difference in weight.
Oon
- FAST / WAW with a SB acoustics - which cone?
