I had read alot about faraday ring, which have advantage of reduce imductance and provide more linear motion, etc.
But how to construct and what is the shape ? I heard some said plating the surface, but not so much info about it.
(I)Should I make it a big cylinder around those surface needed (pole and top plate, well depend on design),
(II)or make it like a coil, similar to voice coil ? (maybe opposite direction ?)
(III)Or make make many short cylindrical ring, stack together with insulation, means shorting in a ring, by layer, instead of one big one. (seems like a round layer cake)
I personally think that third one is better ? but may limit by the current carrying capacity, need further design.
SO now, which do you felt the best, or you have better suggestion ? (also can let me know how to make ? hope can be easily accessed)
The most realistic is a pole sleeve on a cylindrical pole. It's quite an undertaking to build a driver, are you sure you're up to it, if you're unsure of what you want to do with shorting?
