X Mini Kai Bluetooth Speaker
Two Speakers For The Price Of One!!
These speakers retail at upto £70 each, today we are offering for a limited time only a pair of X Mini Kai Speakers, for a bargain price of £70.
Pair It, Dongle It, Speak It, Rock It! Capable of delivering high quality sound through Bluetooth transmission from a paired device, the X-mini KAI Capsule Speaker has been designed to feature a built-in Bluetooth module while keeping to the unmistakable quality and form of the original X-mini Capsule Speaker. In addition to the convenience of wireless audio playback, the KAI adds a built-in mic for easy hands-free conference calling.
Bluetooth-Equipped
Play your favorite tunes from any Bluetooth-equipped device while you control tracks and volume wirelessly from the X-mini KAI Capsule Speaker. The KAI features Bluetooth v2.1 + EDR with A2DP stereo support for high quality wireless audio wherever you go.
Large 40mm Drivers for Higher Quality Sound
Magnetically shielded 40mm drivers in the X-mini KAI give you that extra edge over conventional 36mm drivers when it comes down to sound quality. Experience rich, full-range sound as the KAI expands to create a larger resonance chamber. It's high quality sound that you can take anywhere.
Multiple Speaker Connectivity
The Stowaway 3.5mm plug lets you daisy-chain multiple speakers. Not only that, but the X-mini KAI Capsule Speaker can act as a Bluetooth dongle to the rest of your X-mini Capsule Speakers and also all other wired audio products. Daisy chain multiple X-minis together using the stowaway 3.5mm audio jack and plug, send your music to one Bluetooth-connected KAI, and enjoy wireless sound from every speaker. Having the option of wired connectivity not only allows X-Mini KAI to connect with a wide-range of devices that lack wireless bluetooth connectivity, but it also allows longer battery life.
Built-In Mic for Hands-Free Conference Calls
A built-in microphone function allows for hassle-free conference calls. It's great for a desktop when you want to listen to your digital music and take calls without the need to dig for your phone. Leave your smartphone plugged in and charging across the room while you still enjoy music and accept conference calls. Thanks to the sound design of the KAI, your caller's voice will be loud and clear, and the powerful microphone makes you easily understood.
Built-in Audio Controls
The X-Mini KAI also features built-in audio controls that allow users to Pause/Play, Volume up/down, and Change songs with Previous/Next button. X-Mini KAI would be full of buttons you might think, well that’s not the case as all of these functions can be performed with a single multi-functional button.
Rechargeable Battery
The built-in Lithium-ion battery is rechargeable via USB and offers an impressive playback time. Enjoy up to 4 hours of wireless Bluetooth music playback time--or up to 8 hours of music when connected via 3.5mm jack--and up to 8 hours of hands-free talk time.
Light-weight and Extremely Portable
The X-Mini KAI is so portable that you can carry it around in your pocket, bag, or purse as you like. It does not takes up much space and only weighs 95.2g. It becomes really small when not in use thanks to it’s unique compressible design. When not in use, users can simply press the upper portion of the speaker and turn it clockwise to close and anti-clockwise to open.
Overall these are great little speakers, which produces high quality sound, are packed full of features and are compact enough to be transported anywhere.
Specs for X-Mini KAI speakers are as following:
Dimensions: 50.0mm X 62.0mm (closed resonator)
Weight: 95.2g
Speaker: Magnetically Shielded 40mm (4Ω)
Loudspeaker Output: 2.5W
Frequency Response: 100 Hz – 18 kHz
Signal-to-Noise Ratio: ≥89dB
Distortion: ≤0.3%
Playback Time: Up to 8 hours
Battery Capacity: 550mAh
Battery Voltage: 3.7V
Battery Charge Time: At least 2.5 hours
Operating Frequency Range: 2.4GHz – 2.48GHz
Wireless Range: Up to 10 metres/33 feet
Bluetooth Compliant: v2.1 + EDR
Bluetooth Profile support: A2DP Stereo
Bluetooth Playback time: Up to 4 hours
Talk Time: Up to 8 hours
Microphone Sensitivity: -34db
Package Contents:
X-Mini KAI speakers
Charging cable (that doubles as an audio cable extension)
Pouch
Manual
If you are only interested in one speaker then the price is £40 + £6 Standard Postage (Delivery within 3-5 days) And To Be Signed For. If you are interested in two then the price is £70 + £10 Standard Postage (Delivery within 3-5 days) And To Be Signed For.
Please go to X -Mini " Kai - www.qualityelectronics.uk.com to purchase. Payment by Paypal is available for peace of mind and there is a weekly instalment plan option to make them even more affordable.
