Thanks for the link Nigel. Lots of lovely loudspeakers to ogle over!
I see from the link that Fane are celebrating '60 Years of Sound' this year.
I've purchased several Fane 12" drivers over the years and they've never let me down.
My first serious speaker was an early Fane 122/10 mounted in a 5 cu ft cabinet, reflex tuned to the driver's resonant frequency of 40Hz - the bass was magnificent!
I bought my first four Fane speakers for a disco in 1980.
They were Fane 12-50WRMS.
I still have a folded horn Fane speaker I built myself in my living room.
I'll take this opportunity to reminisce Nigel!
My mid 70s disco complement included four Fane POP 55 (60W rms) drivers in two 2x12 cabinets. High frequencies were supplemented by four Goodmans Hifax 750P horn drivers.
The additional two 2x12 cabinets contained full range Goodmans Audiom 12P-D drivers.
The cabinets were aspirated by two 120W Arbiter valve slave amps which greatly contributed to the sound quality - happy days!
P.S. Never got round to using W bins for reasons of transportability - we moved our gear in two Mini vans!
I just used simple sealed boxes for my disco cabs.
I used a 225WRMS Maplin disco amplifier.
They were incredibly loud.
Not sure if mine were pop 60's , I am pretty sure they were 50WRMS and guitar type speakers that worked up to about 3KHz.
I used to work for another disco and he had the "Orange" folded horns, definitely a bit harder to throw around.
Yup, my cabs were also sealed. That's why they could take a pounding and still survive!
Was simply a case of sticking the drivers into the ready made, empty cabinets which were readily available back then. No regard was given to enclosure volume etc - the darned things just worked, and worked well (in the disco context)!
P.S. Fane POP 60s were 15"/60W rms drivers that could be used for any instrument or for PA purposes, and they worked up to 5kHz.
I did the same and they just worked.
I started off with a 4 by 12 inch cabinet but then found it wouldn't fit in the car ! So I sawed it down the middle and made two boxes. With castors on the bottom they were a dream to move around.
I used coiled guitar leads for speaker leads. They worked OK until tripped over one at a gig and it pulled out shorting out the amp.
Luckily the Maplin amp had a fuse on the output and that blew before the output transistors. A change of fuse and off I went again.
Uncanny! I did exactly the same thing before purchasing the commercial cabinets!So I sawed it down the middle and made two boxes.
Naughty Nigel!I used coiled guitar leads for speaker leads.
In the interests of safety we'd better say do not use instrument cables as loudspeaker cables!
P.S. Your drivers may have been Fane POP 50 (50W rms, Fres 75Hz, 8kHz).
- Live Sound
- PA Systems
- Fane's new website is live
