Please add:
Uncut Aluminum/foam sandwich for arm boards, 6” X 6” $10.00
Aluminum 3-point cartridge coupler $10.00
Premier HL-29 LC-OFC Copper Litz headshell leads miss-matched set $8.00.
To my request and provide the final amount I should send you. Thanks
Will do. I'll get it boxed up, weighted and let you know the total is, minus what you already sent.
Tubes
Gates 833a for display, not working? No way to test $5.00
Raytheon Type BH globe. Stamped 1939. Cold cathode rectifier. Unable to test? $5.00
Caps
Old TRT Wondercap 3uf 425 Vdc $3.00
.012uf 1200v vintage Mica Large chassis mount postage stamp $2.00
.001uf 1200V vintage Mica Large chassis mount postage stamp $2.00
Transformer
PK-31 SE OPT 5K/8 ohm 5W $5.00
SPK Stuff
Audax DW50m Tweeter w/wedge mount, 4 ohm 94db. $20.00pr w/tilt mounts NOW $15.00
Blaupunkt P652c 2 way coax 6.5” 4 ohm, 91db 65 to 20Khz 40W NIB pr $15.00 NOW $10.00
EV FS-1950 spider for 15” $3.00
EV VC-9200 voice coil for 15” $3.00
EV SR-15 basket gaskets pr $1.00
EV DC7172 dust caps 2.75” $.50 ea or 10 for $3.00
Waldom AA-78 spk cement 1QT NIB (can) $4.00
Waldom AA-76 spk cement 1 QT NIB (can) $4.00
Books/Mag
Electronics Magazine May 1943 and March 1944, great collector’s items. $4.00 NOW $2.00
Radio Physics Course by Alfred Ghirardi, 1933 2nd ed. This has it all, tube, transformer theory $6.00 NOW $3.00
Other Stuff
Distech Silver Plus Interconnect, 3’pr $20.00
Pioneer SX60 amp section, 60W/ch, Xfrm, caps, running, works great. $10.00
RCA PR8065 5 disc CD changer $15.00
Iwill KA266 mother board w/ AMD Athlon CPU 1 Ghz, 512 mb, PC100-DDR ram, Radeon 7500 PCI video bd (CRT-DVI-S Video out) and I/O magic 56K modem. All working $5.00ea or 4 for $15.00
Powork PW450 computer PS 450W $8.00
Kodak Zi6 HD camera $40.00 obo
Guitar Parts...send for list.
Caps
Transformer
SPK Stuff
Books/Mag
Other Stuff
More Books
Thordarson Tru-Fidelity 1961 product catalog. Transformer specs, tube circuits. Photocopy, large $2.00
RCA Transmitting tube book. Photocopy, large $2.00
Transformers
Tomiko OPT-SE 09 rev 2. 0-3.5-5K/0-4-8 ohm, 12 watt -18 watt max, DC 165ma max, used (4 hrs maybe), exel cond, uncut full length leads. (see eBay for description, new $45.00) $30.00
Transistors
Phase Linear XPL909 (3), PL909 (2), SPD164 (2). $7.00 set
RCA 66546 (7703) (2) $2.00
SPK
Mylar Done Tweeter, .75” 8ohm, 92db, 50 watt. Purchased from MCM p/n P11028 $10.00pr
Other
Magnavox DVD Model MDV456/17 $5.00
Harmon Tech DVD Model 202 NIB, never opened or taken out of plastic. $5.00
Cleaning out workshop, more items to come.
Transformers
Transistors
SPK
Other
Capacitors
Oil/paper
GE Pyranol 50uf 330vac $15.00, 20uf 330Vac, $10.00
Captron Type III 27uf 700Vac (2) $10.00 ea
Philco 10uf 600Vdc $6.00
Sangamo 8uf 600Vdc $6.00
Sprague 8uf 1000Vdc $6.00
Pyramid 8uf 600Vdc NIB (3) $7.00 ea
Micamold 6uf 1000Vdc $5.00
Unmarked 6uf 600Vdc $4.00
Cornell-Dubilier 2uf 1000Vdc $3.00
Lot deal $50.00
Oil/paper
Lot deal $50.00
Transformers
Altec/Lansing 1200Vav 150mA +, Bias tap, 6.3Vac, 5Vac. Large(heavy) matched pair out of Simplex theater amps. $30.00 pr
30038-2b 600Vac CT 100ma, 6.3Vac, 6.3Vac, 5Vac $10.00
MTcg 5C171 600Vdc 60ma, 6.3Vac, 5Vac (2) $10.00ea
T849-115A 800Vac 125ma, 6.3Vac, 5Vac $10.00
Stancor P4089 6.3Vac 6 A $8.00
Stancor P4019 6.3Vac 3A $5.00
Choke
HP/Paeco 6H, 125ma (2) $10.00 ea
Other
Aiptek T20 Pocket Cinema, 640 x 480, 8 ANSI Lu, usb. Only used once. $20.00 obo
Choke
Other
Transformers
Altec/Lansing 1200Vav 150mA +, Bias tap, 6.3Vac, 5Vac. Large(heavy) matched pair out of Simplex theater amps. $30.00 pr PENDING SALE
30038-2b 600Vac CT 100ma, 6.3Vac, 6.3Vac, 5Vac $10.00 PENDING SALE
Transformers
Correction: both transformers below have CT secondary HV.
MTcg 5C171 600Vac CT, 60ma, 6.3Vac, 5Vac (2) $10.00ea
T849-115A 800Vac CT, 125ma, 6.3Vac, 5Vac $10.00
Sound Practice Magazine
Vol 1 thru 16, Vol 4 missing, Vol 5~10 are photocopies, all the rest are originals. All $8.00 (more fun than a $8.00 pizza)!
Glad you got them. The holiday shipping season is in full swing, and you never know when something may get lost. I seem to lose something each year.
MORE ITEMS
Lambda Model 28 tube regulator, 200~325 Vdc 100mA, 6.3Vac 5A. Fully functional w/tubes $100.00
Simpson Series 55 DC amp meter 0-25ma range #55F-1570 on box. NOS $10.00
MORE ITEMS
FOR SALE/TRADE
5963 untested but all good (purchased at ham fest from trusted seller) set of 12. Would like to trade for a few 12AT7. If interested send PM and I will sort through and list MFGs
More Items
ICs
AD711an $3.00 ea (4)
AD712an $4.00 ea (4)
AD744an $4.00 ea (4)
AD797an $ 10.00 ea (2)
MosFets
2SK405 Real vintage 80’s Toshiba (4) $10.00 ea
2SJ115 Real vintage 80’s Toshiba (4) $10.00 ea or $70.00 for all
2SK135 Real vintage 80’s Hitachi (4) $8.00 ea
2SJ50 Real vintage 80’s Hitachi (4) $8.00 ea $54.00 for all
Transformer
Hammond PT125se 15W/80ma used only for prototype, uncut leads $35.00
TT
AR spring set $5.00
BluePoint needs stylus ($100.00 trade in value at Needle Doctor) $25.00
Constranied Layer Alu/Delrin/Alu sandwich, great as TT arm mount, tube chassis top plate, etc. Custom cut to size, max width is 8”, max length is 19”. 6X6 $5.00
DIY oak arm tube 7” $5.00
Other
Distech Silver Plus interconnect, 3’ pr $25.00
DIY 1/4”Copper Foil/Teflon flat interconnect w/ HQ Gold RCA 3’ pr $15.00 (worth that in RCAs)
DIY 1”Copper Foil/Teflon flat speaker cable 6’ pr. $20.00
Trades Wanted
OPA2134, LM4562, 1578melz, 45, one old style TRT Wonder Cap 3uf, Cardas tone arm wire.
ICs
MosFets
Transformer
TT
AR spring set $5.00
Other
Trades Wanted
