fake 2sk1058 -- again
last batch I bought (4 pairs) appear to be similar in the picture. except one set has the hitachi logo and the other doesn't. All came from a local store I had bought another four pairs years ago which were genuine.
I did the gate capacitance and source-drain diode check and they all appear as per the datasheet so I'm guessing these must also be genuine. I'll find out soon once the amp is built.
Most FAKES will fail well before they get anywhere near the limits of the genuine article.
If you build the MOS-FET testing circuit and, with the MOS-FET on a big heatsink, push the current up to somewhere near its limit for a short period of time.
You have to de-rate the maximum current from the specified max but the datasheet shows you how to do that.
What this will not detect is another big MOS-FET that has been re-badged.
For that you might need to measure the Vgs capacitance and compare that with the datasheet.
However, if the gain and the maximum current are good then they are probably OK.
There aren't too many fake POWER MOS-FETs out there YET, to my knowledge.
I'm sure our slimy cousins will get around to that in due course.
SLIMY as in the criminal fraternity.
S.O.A.R.
Is indeed Safe Operating Area.
If you look at a datasheet you will find that things dont quite add up:
Lets take the 2N3055.
It has a maximum Vce of 60V and a maximum collector current of 15A.
"SO" you think, it will dissipate 60 x 15 = 900W
WRONG - It can only dissipate 150W
AND, it can only dissipate 150W when its junction temperature is at about 25 Degrees C.
As it gets HOTTER it can dissipate less, hence de-rating.
From the temperature de-rating curve in the datasheet you can work out how much power it can dissipate at say 60 Degrees. I'll guess as I don't have the datasheet open at the moment, but it might only be 60W.
Now it can still withstand 60V and it can still pass 15A BUT NOT AT THE SAME TIME.
The SOAR is where we as designers have to keep the device within its safe operating limits by limiting the current and/or the voltage as the junction temperature increases.
I know there are many more factors but I am trying to be simplistic for someone who has never heard of SOAR.
I found this small tool to read those really tiny marks and letters on the transistors. in this case on the 2sk1058 says "Malaysia F4 9"
Hitachi those series MOSFET is no easy fake
Because they have the following characteristics:
1.Middle pin is the source(Most of MOS transistor the middle pin is the drain)
2.Turn-on voltage is less 0.5V(Most of MOS transistor turn-on voltage greater than 1.5V,unless low breakdown voltage MOSFET)
You can measure directly with digital multimeter ‘diode’ whether it is a fake.
