Faital 3WC Building Advice
This 15" is working well from 85 liter sealed, so 115 is fine, you need stuffing too and it can increase a little the volume, making Qtc lower so a little higher f3 but in a flat it should be more than enough...15" is a serious size in a flat. Yes the bafle step should change too, but you can eq with the minidsp. You can try a xo from 200 hz...perhaps 400 hz will no force you to sacrifice too much spl loss with 8" cause the bafle step loss. The high pass should be more tricky...1500 to 2000 hz cause a 8" is beaming sooner than say a 5" mid. If the sound is tireing, makes it dive from circa 1500 hz to 15 k hz...5db or more according the room.
I'm thinking about the best solution for me. of course I would make measurements with Rew, adjust the phase etc... but so as not to find myself alone, I am looking for DSP presets for hypex so as not to start from 0, measure and modify the existing EQs... I am leaving rather on crossovers of the woofer at 200-300Hz
There is a dsp preset for 15pr400 or another 15"
To experiment, I would have to filter my medium 8M400 and 15PR400 in active mode and add the SBAcoustics TW29BN Tweeter to it, but filter in active mode...
But for that it would be necessary to know the value of the 4 components of the Tweeter in the diagram of the faital WC-15
