Factory Built F4 -double transformers
What would the benefits, if any, be if I install a second Plitron 300VA transformer in my F4? It would have one serving each channel though the rest of the power supply is not independent for each channel.
So would I gain anything? Thanks.
Well, add in a second capacitor bank (resevoir) and you will get more of a resevoir of charge and with the second transformer (power supply) you'll be able to fill that reservoir quicker than with one power supply.
The only improvement that can be noticed is if you can actually empty that resevoir and fill it back quick enough versus not being able to fill it back up quickly enough or not having a big enough resevoir.
On the flipside because I am bad at explaining things is (from what I can figure out from previous readings) is a hugely massive capacitor bank and an overly huge transformer is not needed. If you can not drain/consume it all, you don't need it vastly overbuilt as there is a maximum to how much your transistor can use.
I'm thinking ImPasse -- I have a bunch of really premium 6SL7 and 6DJ8 laying around unused, as well as a suitable power transformer, etc... 😎
Manolo47 -- what are you using as a preamp into your F4?
70Vpp is for :Pumpkin:
Brynhildr is ........ wakoo ZM's mind :devilr:
