Hello
Anyone here have any experience with faceplate LEDs?
I'm looking to put a single LED in the faceplate of a dissipante chassis, 10mm thick plate, and would like to know what others have done for a flush finish. I'm thinking of using a RGB and having it fit either flush or recessed a bit and would like the cleanest finish look to it and would like to know what LED and moreso what kind of drawings or info to provide the manufacturer.
S
S
I like drilling through with a 2 mm drill bit and counterboring from the inside of the panel with whichever drill fits the LED. That creates a 2 mm indicator.
Tom
Tom
Seems straightforward
What brand LED you using Tom?
Just a quick search didn't reveal any 2mm RGB
I suppose that I could drill a smaller hole for the light to pass through and the larger for the LED to set in.. I'll have to test some on a spare piece of aluminum.
S
S
I think he suggests you relieve the back of the panel with the counterbore so there is a 2mm hole that the LED shines through. The LED sits in the counterbore. No penetration, just light coming out.
Might want to practice on something that doesn’t matter to get the desired effect.
I like using a clear epoxy as a lens in aluminum, with a light source behind it. Can drill the hole, fill it with epoxy, drill again a bit from the back to create a more uniform surface, then install an led and see what it looks like.
A small piece of something like wax paper covering the hole on the appearance side, held with tape, will make a shiny surface on your new lense when using a clear epoxy. May help to have something apply pressure so the epoxy stays flush or just under the panel depth, wouldn’t want it proud of the panel surface probably.
Thanks for the good idea.I like drilling through with a 2 mm drill bit and counterboring from the inside of the panel with whichever drill fits the LED. That creates a 2 mm indicator.
Stand the tubes/cans of epoxy in warm water to warm it up so it flows easily & bubbles escape.
Overfill the hole so it creates a dome and it will dry clear/smooth: not so overfull that it runs over your panel.
If you under-fill the hole; as the resin hardens, it will shrink & have rough finish.
- Design & Build
- Construction Tips
- Faceplate drilling for RGB LED
