I have for sale the F7 clone kit fully built and used for around 100+ hrs in a 5U/400mm case. I have since moved to SIT amp this amp boards are not being used and would like to go to a deserving member. I got this fully matched kit of parts including the PCB boards from one of the forum member. All high quality parts with PRP resistors, matched ALFET transistors, pre-trimmed original bourns trimmers and I got the matched Toshiba jfets from the store. The matching info as the numbered stickers which was sold to me I have retained it on the pcb board for reference. As these PCB boards are not UMS compatible I used wires to mount the transistors. No difference in sound quality and it works well and can be easily used with UMS chassis or pre-drilled mounting hole chassis. I have left the power cables soldered to the PCB and if the buyer wants can desolder the same including the high quality silver plated PTFE input cables. Asking $175 including shipping within CONUS states.
Let me check and msg you back on PMWould you consider shipping to The Netherlands?
Going to the post office today. In the meantime can you PM me your full address to check the rates.
thanks
thanks
Any news?
