Trying to confirm how many JFETS I need for a stereo F6 kit-
Is it a matched quad of LSJ74/LSK170 ±0.1mA Matched Quad (Grade B) for $39- does this line item provide 2 of the LSJ74 and 2 of the LSK170 and am I going to use one of each per channel (2 on each board) for a stereo amp?
Getting ready to order and wait until they're in stock again in January and don't want to order wrong. Theres also an Octet option for $89 so I'm double checking.
thanks !
thanks !
From what I read, one set of 2SJ74/SK170 per board, so a global set of 4 units.
Read F6 PDF if it's necessary or not for each set of JFets to be matched.
Same question for Q1/Q2
Transistors for F6
Am I right in that in addition to the set of four JFET's you also need the backordered transistors for a stereo F6 amp kit?
these?- if so, are there other sources for these or should I just wait for them to be back in stock ?
these are the ones I'm asking about - thanks
Included in this kit are the semiconductors needed to complete an F-6 amplifier, with the exception of the input JFETs, which can be sourced separately through the store. MOSFETs were matched in accordance with standard operating conditions. This is enough transistors for 2 channels (one stereo amplifier).
4 - IRFP240
4 - 5.1V Zeners
Please note: the numbers on the MOSFETs are ID numbers only, and are not related to their measurements nor their matching.
4 - IRFP240
4 - 5.1V Zeners
