Hi Just ordered parts for F6 build, and find that the 6V zenners are on backorder till(10/23 ?)
I have 6.3V parts i could use, yes??
i presume it would not make a lot of differance ?
That's fine. The pot adjustment will just be a little less. Aren't those actually 6.2V Zeners?
Be careful when you turn the amp on. The pots have to be preset, and I think one works backwards.
Have you seen my led mod.
This is an improvement over using zeners.
LED mod = three little green LEDs in series.
Why? Better voltage regulation, and negative temperature coefficient.
