F6 Illustrated Build Guide
I can buy two Block RTE 200/2x18 Ringkerntransformator 200 VA 5.56 A for 64 euros (32E p.p.) or I could go with Ringkerntrafo 500VA 2x115V -> 2x18V / 1x36V Sedlbauer, RSO-825059 (€95). Of cause I can save up to buy a Toroidy TTSAS0500 - SUPREME AUDIO 2x18v 500VA (€184.66).
There's also a cheaper Sedlbauer version which is €65.
Sedlbauer 859780 Ringkerntransformator 1 x 230 V 2 x 18 V/AC 500 VA 13.88 A
Spoilt for choice, but which is the smartest? 🙂
freebee,
The Tea-Bag power supply PCBs are well made, and have space for 8 capacitors if I am not wrong. As silasmellor has already mentioned, you will need more space for two power supply boards - so please check the chassis size and see if 2 x transformers and 2 x power supply boards will fit.
then you could use any of these two, while powering up , to check is there any DC offset on output ?
and there it must be , sole explanation for burned R4 (ref. sch in post #1)
check output mosfets , replace what's burned
best to remove them both and re-check do you have proper function of biasing voltage trimpots.... meaning - observing voltage at gate resistors confirming voltage values on both end trimpot positions
during mounting of mosfets - proper torque , big washer, split washer , continuity with heatsink check ...... all these are necessary details
BuB = Beware of Burrrrrrrrrrrrrrrrrs
:clown:
Can someone please guide me how to check the conditioning of the mosfets? I will desolder them tonight, but how can I measure to see if they are burned inside? Which legs should I measure with the multimeter to check for proper functioning? I checked the datasheet and diagram of the IRFP240 but I am not sure where to measure.
Thanks in advance,
Koos
Hello lads,
I almost finished my F6 build and I'm now trying to set the bias.
I'm having my meter across the 0.47ohm source resistor but there is no voltage at all (on both side) =(
I did test my PSU and it works fine.
Am I missing something? Thanks for your help!
