.... except M2
as much as you know , why is the M2 "better" than the F6 , if it truly is 😉
I agree with ZM. It sounds better. It has to do with the signature of using the autoformer for gain. Magical.
Apologize for newbie question.....will be ordering Jfets.
Is matched pair 7~8mA Idss range idea for F6 built ?
Those would be good for F4, F5, F6, M2...
Dunno IF you've noticed yet but imo sane individuals eventually realise this.. ..that In Real life there is "always" Better.
Regardless of whatever Human endeavour.
Real Trick is to realize when enough is enough 😉
Hi all,
searching for a reputable source of 2SJ74/2SK170. Found 2:
2SK170BL+2SJ74BL VERY LOW PRICE!!
and one seller on ebay with good feedback (price is reasonable too):
2SK170BL/2SJ74BL low noise N/P-channel J-FET matched Idss to 0.1mA 1 pair !! | eBay
anybody had experience with this sellers?
Thanks,
Giorgi
Thanks,
Giorgi
Been a while since I built mine, seems like some said around 6 idss was best? Or am I imagining that? I think mine were 7.5.
Russellc
they're all Sissy amps
except M2
And hopefully "Unconstipated" M2(5).
Russellc
Hi, I'm looking for a couple of Jensen JT-123-FLPCH, obviously no answer by Jensen, instead I find a couple of
Jensen JE11SS-EL but no way to find a datasheet.
Hope someone can help
Vito
Vito
Hi Vito,
I ordered from this listing on ebay recently:
1:1 or 1:2 Line Audio Output Transformer Jensen Transformers JT-123-FLPCH | eBay
They're out now, but you might try contacting them if they can get more stock.
Shipping isn't too bad if you pick the cheaper options.
Hope this helps.
Dennis
Hope this helps.
Dennis
Vito
Not sure how difficult it would be for you but I called them after I sent them an email and finalized the order over the phone. I can PM you the contact I made the order through over there if you like.
Similar to 'Blk', I sent an email to Jensens to purchase a pair of the transformers, and they replied with an invoice and I had the transformers a few weeks later - very easy communications.
Finally F6 is all done, first tried with BA3 as pre and assembled in the same chassis. Amazing soundstage but noisy due to cramped up space even 5U chassis is less than optimum. Removed the BA3 and everything stabilized. Appropriate biasing, offset around 4mV both channels...dead quiet. Without the pre it sounds a bit deficient but still great.
I am however stuck with a different problem now. The amp is blowing fuses on powerdown...not only blowing them but breaking the glass in very small pieces. I am using a CL-60 on live in, something I did exactly for my F5 and the first fuse worked perfect till i resused the PSU in F6. I am using 1.25A slow blow fuse with 230V AC mains. I am using 2X18V 600VA torroid. The PSU/chassis is grounded via a CL-60 to mains earth... standard i used in F5.
At what voltage are people generally biasing the F6 to? I recently bought someone's build, and it sounded really good. It was running a fair bit cooler to the touch than other class A amps I've played with, so I checked the bias and both channels were set to 0.474 volts after an hour of being on. I brought it up to 0.51 volts and nulled the offset. But I think it sounded better at the lower bias point. So I am curious to know where other people are setting their amps to.
I`ve biased mine at 0,50something V. The F6 and me are happy with that.
Micha
Friends...this thing is eating my fuses, changed it to 2A slow blow, no change. NP schematic is 1.25A for 230V operation. 25th replacement in. All temperatures on transistors/MoSFET's are standard, amp is dead quiet, sounds amazing, bias about 0.6V both sides...
- F6 Illustrated Build Guide
