Hi everyone,
I need your help to understand what's going on !!!
My right channel is having an strong dc at the output , P1 has almost no effect on it ( from 18.28 V to 18.42 V )
here are some measurement :
6.2 v across Z1 and Z2
18.8 v dc across R7
18.20 V dc across R9
16 v dc across R3
0.515 v dc across R2 ,very stable and easy to set
0.592 v dc across R1
42.2 v dc between output and R2
16.5 v dc between R3 and output
R1 and R2 are 0.56 ohm
Q1 and Q2 are new , from Mouser
Main supply +24.1 v / -24.0 v
Noise supply 2.0 mv AC
18.8 v dc across R7
16 v dc across R3
I use the store board , in stock mode , without any mods , other than zener 6.3 v .
some more measurements :
42.2 v dc between out and V-
- 5.8 v dc between out and V+
17.0 v dc across R9
0.070 v dc across R10
0.194 v dc across R11
0.000 v dc across R12
R2 and R3 are hot , rated 5W
Q1 is new , the old one behave the same .
ok , I will change it , and let you know .
i forgot to say that R11 and R12 are 110 ohms , will it change anything ?
As you said Zen / Alvin , changing Q1 solve the problem .
my IRFP-240 were new Vishay's from Mouser , but new doesn't mean always good 🙄
thanks for your help , useful as usual 😉
- F6 dc offset issues
