I could use some guidance/help getting one of the channels in my F6 to work.
The B channel is the first one that I powered up, and I am able to bias it with no problem, however the A channel/board is giving me problems. The more positive the bias goes the more negative the offset goes. Can only get to .10 vdc on the bias before I run out of adjustment on the offset pot. Thanks.
Is this about the FirstWatt F6? If so, you'll probably get more responses if you post in the
Pass Labs forum.
Pass Labs forum.
