F6 and biamping
Helo. I want to build a power amplifier. F6 looks like the simplest. My speakers are troels gravesen jenzen next. They are ratet at 87 db so I would need to biamp. From what I understand several off the pass design is lover gain than "normal". So my question is: what class d amp to pair with the f6. I might Explorer the 6-24 biamp curcuit and remove pass filter between bass and midrange.
I also use convultion filters for bass in roon dsp.
For preamplifier I have and aikido 6sn7 octal.
Build a pair of Neurochrome Lm3886 amps (google) ??
Sounds are Not quite same as F6.... but the difference is Slight 🙂 and those 87 db Troels speakers will Never know the difference.
Well I already have big amp. I wanted to build a sweet and simple class a design. Chip amp is not an option. I kneed sugetions for suitable amp to bi amp with. Same gain structure. Ore other way around the problem.
Maybe I should have posted in class d section.
