This group buy is closed. Here are some links to the threads related with EUVL´s F5X:
http://www.diyaudio.com/forums/pass-labs/172770-balanced-f5-question.html
http://www.diyaudio.com/forums/pass-labs/183362-f5x-euvl-approach.html
http://www.diyaudio.com/forums/grou...5x-designed-case-user-distribution-check.html
http://www.diyaudio.com/forums/grou...l-mpc74-fukushima-resistors-gb-euvls-fx5.html
http://www.diyaudio.com/forums/group-buys/192553-gb-2sk3497-2sj618-euvl-f5x-other-projects.html
http://www.diyaudio.com/forums/group-buys/190405-b-prp-resistor-group-buy-euvl-f5x-build-b.html
http://www.diyaudio.com/forums/group-buys/187524-potential-other-group-buys-related-euvls-f5x.html
http://www.diyaudio.com/forums/group-buys/205531-potential-group-buy-f5x-components.html
Triode4,
Why would you want to order a transformer from Poland and pay expensive shipment across the Pacific, when you can order them from SumR or Plitron who are much closer to you ?
Contact Horio by PM and he will tell you details about ordering from SumR. There was already a first GB for F5X Transformers a couple of years back.
Regards,
Patrick
Regards,
Patrick
Contact Horio by PM ....
There was already a correspondence triode4 <-> Horio.
Thanks for Antonio providing me the additional info.
- Toroidy will provide the same pricing for the 100-115VAC countries for the aux transformer, see post #14 for specs and pricing. However, shipping method is unknown. I have yet to contact them.
- Alternatively, we can purchase Avel from partsexpress.com. The only open question is whether the diameter is too long as it is 8mm more than the specs in post #14. Otherwise, it seems to fit as well. Maybe anyone has the F5X case specs can help providing the answer?
Please post your interest if you are also looking for the 110VAC aux transformer.
Davide, I added you as you asked. Feel free to remove.
pchw - 1 x 110 aux transformer
nikon1975 - 1 x 110 aux transformer
Thanks,
Thanks,
Fred, the "Avel Lindberg" you have selected is probably too large. I've found a smaller Avel Lindberg product.
For precise size requirements, see this posting and the answer to that one.
I think there is no point to explore other alternatives. I emailed to Tomasz of toroidy for the 110VAC toroids info. Please express your interest here.
Horio - 2 x 110 aux transformer
CanAm Man - 1 x 110 aux transformer
First response from Tomasz, but no quote yet ....
I have followed up with inquiry for more shipping info. Stay tuned.
Dear Fred,
It's not a problem to produce transformers with 2x115V primary but the shipping cost (prioritary) to USA or Japan will be very high.
Best regards / Serdecznie pozdrawiam,
Tomasz Lachowski
PWPH Lachowski - TRANSFORMATORY
ul. Mazowiecka 20
16-002 Ksiezyno k/Bialegostoku
tel: +48 85 7474378
fax: +48 85 6631213
TOROIDY.PL Transformatory Toroidalne Producent, Audio, Separacyjne, Trójfazowe, 230/110V, 110/230V, Na zamówienie
info@toroidy.pl
BLOCK|RK15/12|TRANSFORMER, 15VA, 2 X 12V | Newark.com
MULTICOMP|VTX-146-015-112|TRANSFORMER, 15VA, 2X 12V | Newark.com
Many others available in the US.
Only for logic circuit. No need to import from Toroidy.
Patrick
Patrick
- Group Buys
- F5X Transformers
