As I said in the email, the USPS tracking sucks. I do not know why they even have it. Another member just received some fets he ordered before it showed them even being delivered. I cannot do anything once it leaves my hands. The only alternative is UPS or FedEx and they are usually double to triple the price.
I know is not more in your hand and I don't want to blame you... just inform you about the status.
FYI: USPS works flawless to Norway 🙂
BTW : thanks Buzz....... only small part to collect for fall season 🙂 ,taking summer brake, then 4 mono blocks hopefully 😉
Hi Buzz,
the build is started and I have some question:
- the R26 in the schematic is 47.5K instead of 10K as R25. It is correct?
- the R29 and R30 are 475 but was not in the kit. No problem, I have the 475 but is the correct value?
- the R7/R8 and R9/R10 have been substitute by the WP195 - 120ohm. Need heatsink?
Best Regards,
Emyeuoi
Best Regards,
Emyeuoi
R26 was labeled incorrectly.
R29/30 should be 475 for gates of bjt.
The Caddock R120 takes place of two 220R. THey were suppose to have small heatsinks included, although they do not get very hot
Thanks buzz... I have 4 small heatsink in the kit and I will use for the transistor.
Actually is very difficult for me found them here... maybe you can send me with the transformer.
With cascode R25/R26=12k and R27/28=5.6k, what's a good value for C5/C6? Didn't get those caps with my kit.
Also, is there a part recommendation for (optional) compensation caps C3/C4?
Thanks!
BK
Thanks!
BK
10uF. Ill send you some if you need them. They act as a filter. C3/4 most likely will not be needed.
If you can sneak some in with the transformers that would be great. 😀
BK
Hi, Buzz
I was in the most recent GB for a F5T V3 kit. I received the kit a few weeks ago already and thank you for organising the GB. I plan to start the build a few months down the road. However, I just realised that I do not have the component list of the V3 kit (meaning I do not even know what components are supose to be in the kit 😱). I am sure there such a list exists somewhere. Can you tell me where can I find it? Thanks!
Regards,
Regards,
Since I did not hear from Buzz, just wondering whether anyone in the GB has a list that described what components are supposed to be in the kit for a F5T V3? As mentioned in my previous post, I received my order (for a F5T V3) a few weeks ago but I have no idea what components are suppoed to be int he kit. I want to make sure that eveything that is required for the build is in the kit.
Any help from anyone will be appreciated!
Regards,
Regards,
- Group Buys
- F5T Premium kit GB
