If you get the diy virus, i cant hekp you there😀
So, my symptoms are: just finished two monoblocks Aleph60(still tweaking... I thing getting there), spend all Thanksgiving making Troels' PMS, got myself 4 SemiSouth for future F6, and looking for this nice F5Tv2 kit... 🙂.
Ok, I understand about monos, but how you suppose to mount these PCB's into it? One board/ch, BUT two sides, two heatsinks/ch?
Store PCB or TeaBag PCB. Truthfully. V2 should not be a problem for big store chassis. You would have one channel per side, either way. With store board, I would excpect it to be simple. With Tea's boards, you might have to drill holes down low and mount in hi/lo fashion. I can post pic of mine if youw would like. It is done in this hi/lo fashion
RdK 845 - V3, PSU - Yes
RusselC - V2, PSU - Yes
Please continue the list in this format. It helps bookkeeping.
Buzz, is the ony difference between the V-2 and V-3 just the number of outputs? If so, I may (and will change list at that time) upgrade to V-3, still with power supply.
Sort of taken by your comment that V-3 may be the last amp I will need.....
Thanks,
Russellc
Thanks,
Russellc
V3 is increase in output fets and bjt cascoded FE. It will require 32V rails to take advantage of available current and two PSU boards are needed, one per channel.
Hi Buzz,
If you happen to have some MUR3020W spared, I would like to buy a few from you.
Thanks!!
Thanks!!
Dane - V2, PSU - Yes
mkoerner - V2 (2), V3 (1)
mordikai - V2 (2), PSU - yes
mordikai - V3 (2), PSU - yes
Bbeen waiting on the bloody things for a month. Suppose to come this week. We'll see. I have had to suspend the fet GB for that long just because i cannot fill orders.
sts9fan - V3, PSU - yes
I would like to build a 100W V3 with the 4 pairs/ channel.
Do you sell the matched octuplets x 2 separately?
Hi Buzz!
Thanks again for the first GB. So much work. Got my resistors today so I have complete parts kits. I will now be watching the store for V3 boards. Pretty excited! Good luck with the new buy 🙂
Naturlyd - V2 (2), V3 (2), PSU - yes
We are gettin gclose. A couple more an di will go ahead and order. Mayb ew ege tlucky and they are here before Xmas.
- Group Buys
- F5T Premium kit GB
