F5 Turbo Circuit Boards
Andy,
On the V3 output board, is there a way we can shave a little bit off the width (maybe make it a 225mm long board). For those of us who are wanting to build balanced mono-blocks, we have to mount (2) output boards per side of the chassis. Unfortunately a 250mm wide board probably means having to use a pair of 300mm sinks on each side of the monoblock (that is one deep amp). Shaving a little bit off the length of the board would allow us to use 250mm sinks, which there are many to choose from. You could probably shave 10mm off the left side of the board alone, without having to even mess with the FET spacing.
Andy,
Have them cut one in half , you end up with 15 inch depth you are going to need the depth .....
it's simple as that
Your problem is not the number of output pairs, for 75V rails you could get by with just 4 pairs.
With 75V rails, you'd be lucky to reach the 300W/8Ohm mark : 4 pairs is 1200W Pd, 300W is 25%.
Example : Perreaux PMF5550
100V rails, +500W, from twelve 125W power MOSFETs, makes 1500W Pd
MOSFETs no have second breakdown !
Whole philosophy of Papa is built around as simple as possible : minimal number of gain stages, through Class A operation.
Andy,
I've got it down to 243mm.
Enough?
Jacco
Do you have any ideas of what may be suitable replacements for the 2SK170 and 2SJ74 devices?
Andy
