F5 (turbo) as first project: Yea or Nay?
Well, now that, that is taken care of... I wanted to suggest you make your way through http://www.diyaudio.com/forums/pass-labs/168040-f5-2sk2013-2sj313.html for some ideas. Maybe only 1 pair would be fine?
There are also some "mini" F4s with TO220 outputs too but, I don't remember were to find those?
I beleive there is also some LU1014 JFET amps for Cans in this forum but, you searching and reading here can move you forward in this hobby quite nicely. For that mater the Zen9/F3 is an option also.
I think the LSK Pre from BAF has possibilities for your application also. You should check out that thread :D
