One F5 chanel draws 65w continuously.
Two channels 130w
220/130=0.59
Add some losses, but we are far from 3A.
At powering on , the peak current is huge but short.
2 x cl 60 in series will do the job easily
Two channels 130w
220/130=0.59
Two channels 130w
220/130=0.59
Im stupid, a 800 VA transformer wouldnt draw min 3A continuously. 😱
Was thinking about full power out of the transformer.
I could probably do with a single CL60 then, I am bypassing the NTC with the relay anyway after 100-200 ms or so. But using 2 x CL60 might be a good idea, since the inrush current is huge for a 800 VA transformer.
I know most of this stuff but sometimes my mind wanders.....lol.
May be 800va is a bit overkill...
Maybe, but more never hurts, I am going to use Cvillers boards with dual output pairs and I might be rasing the bias pr. channel.
Besides, it is always nice to have a big enough transformer for any future firstwatt projects, you never know if NP has some higher powered versions coming sometime in the future. 🙂
In the F5 manual the power supply is shown with a 0.0033uF cap used for mains filtering.
Would it be ok to use a 0.22 uF X2 275VAC cap instead?
Does it matter much which size you use?
No one knows?
No one knows?
just go for it - it's just 3W across that cap
be sure to check it's temperature while gadget is live - connected to mains
disclaimer - are you sure I'm bloody serious that you're in jeopardy if you're asking that sort of question , and playing with mains connected gadgets ?
basics first , playin' after that .
toyin' with 110/120/220/240Vac isn't best way of puzzle solving
Eh, ok. Your answer is?........Im not totally sure....😕
Basically I just want to know if the higher value of the cap, 0.22uF vs 0.0033uF matters when it comes to filtering. Or if the 0.22uF cap will work fine as well.
Think Neutrality, think!
The cap presents a resistance to AC current and that resistance depends on frequency and capacity.
Question for you is: what is the relation between that resistance (let's call it Xc), capacity of the cap and frequency of the current?
Zc=1/(2 x Pi x F x C) = 1/ (2 x Pi x 50 x 220x10^-9) = 14K5
so - that cap is same as 14K5 resistor across 220V , considering that you're from Danskeland ;
P=I^2 x R
so - I= U/R = 220/14K5 = 15mA ......
P= 15mA^2 x 14K5 = 3W35
imagine 5 or 9W resistor across mains , scorching hot - dissipating 3W35 ....... that's so-so imaginable ....... but cap dissipating same amount of heat - ringing "I'm gonna explode !! "
in any case - caps are cheap , but with presumable intention - to buy exact and proper ones
P=I^2 x R
Well, then why even make a mains rated 0.22 uF cap when the thing really cant be used for mains filtering anyway due to power dissipation. 😕
And thanks for the answers. 🙂
Well, then why even make a mains rated 0.22 uF cap when the thing really cant be used for mains filtering anyway due to power dissipation. 😕 ...
Thats a good one
Mains filtering is usually a bit more complex than a single cap - it can involve coils and bunch of other parts that make your head spin 😉
Anyway, Ill stick to the value used in the F5 manual.
Using a 3.3nF X2 310VAC cap.
EDIT : I have never worked much with mains voltage, hence the somewhat stupid questions.
Good choice on the cap! 😉
Those were not the the stupid questions, stupid would be to mess with mains without knowing what are you doing...
In the old days I thought a cap across the mains was to avoid destruction of power switch contacts
Speaking of mains filtering. I have some EMI filters in the form of cord plugs that I plan on using. Is there anyone else that has used this type of plug? It has a schematic on the sticker that appears to have a 0.1uF cap across the + and neutral, then 0.4 mH coils in series with both lines, and finally two 2200pF from + and neutral to the case.
Thanks,
Everett
Thanks,
Everett
has anyone built zobel networks for their F5, or is it not necessary for this topology? I'm running higher capacitance CAT5 cables (10ft)
- F5 power amplifier
