On the other end, even with the pcb that I have (Cviller V1), it does not take much to stick a 5 ohm resistor on the source of the jfet. It sounds too simple, that's why I did not do it yet.
D.
D.
The jfets have to be chosen precisely also.
Imho, it's more interesting when balanced.
i know you are helping me, But i want a simple single layer pcb layout of at least 3 pairs of trannies. double layer will be a bit difficult for me as double side pcb not available here only single side.
If i want double side i have to travel 60 kms . If no option then i will make a double side version.
Also ther are so many versions i am a bit confused. i need output of 200 watts at 8 ohms.
Why not just go for 12,000 watts? Solid silver wound transformers all in a case carved out of a 400 lb billet of solid gold encrusted with diamonds and rubies and sapphires?
Do you think this forum is a genie in a bottle? How about building the original circuit first before you dream up something you'll never finish?
I agree wholeheartedly.
The F5 is universally loved by those who build it. You really should build one 'stock' and see how wonderful it is.
If you need more power, just build more and bi-amp or run monoblocks. There are a number of people who have done that to great success.
If you need more power, just build more and bi-amp or ....
Or in parallel And bridged.
Like for example this critter : http://electronics-diy.com/pdf/Sony_TA-NR1.pdf
The later edition TA-NR10 is basically the same, but an All-FET model, with one-off J201/K1530 output devices (2 times 5 pairs in each monaural amp)
Take my word that a parallel/bridged F5 doesn't sound inferior to a bridged TA-NR10 setup
Guys i searched a lot , but not able to find pcb layout of krell ksa 100 can any one help.
I got pcb layout of krell ksa 50 but no component layout.
I think its a project for the experienced, and not a beginners thing
I suppose its pretty hot where you live
If so I wouldnt build classA
small one, maybe
but big one, no
for a first project I would not suggest amps with multiple matched outputs
in your own interest, find yourself a nice simple amp to build, to start with
if you hope to build a top grade amp there are a few things you need to learn first
its not something that happens in the first try
Viki,
This section of the forum is for discussing Pass amps and in particular F5 amp. For your queries and help regarding Krell and other such amps, you need to post in the solid-state section. You are only going to **** off people here, by continuously asking questions which this section does not address normally.
My request therefore is to do research and post if any queries in other relevant sections of DIYA.
Cheers.
very sorry for annoying you guys,
I got some helping ans here so kept on asking.
keep up the good work
Bye
It would have been of great help.
Bye
Reminds me of that scene in Caddyshack.
"I want a hamburger, no a cheeseburger. I want a hotdog. I want a milkshake. I want potato sala--You'll get nothing and like it!"
Bye
the point is, it will be a complete mess if we go too much off topic
members come to F5 thread to debate F5, and not something completely different
ask your questions in appropriate threads, and you will get proper answers
wish you luck
moderation
Bye
Hi viki,
please, run away from A class amps, go to AB, f.E:
Project 101 - High Power, High Fidelity MOSFET power amplifier
It's a very good amp, not expensive and not hard to build!
So, P1 & P2 should be set a minimal setting before powering up the F5?
I think I may have a cold solder joint, can't seem to get thing out of one of my P2 pots.
Now this is clear, what about the matching story? I understood that the 5 ohm give an asymmetry to the circuit to compensate the difference of the devices. Then, how to choose them ?
Thanks,
D.
If you are planning on doing the 5ohm degeneration trick you need:
1) N-P matched mosfets for each channel.
2) 2SJ74 with an Idss about 1mA more than 2SK170
3) either add 5ohm resistor between the 2SJ74 source pin and the feedback node, or replace R with 15ohm and feedback of 75ohm.
All three steps are required.
Only if you want perfect even harmonics cancellation.
And the cancellation works for single ended F5 just as well.
Patrick
Patrick
I'm using Caddock MP930 resistors for the .47R and 50R feedback will 25C/W clip on sinks be big enough?
Marra
Marra
Maybe this is a silly question but...
All the cool guys with nice equipment make the tuning looking at the distortion at 1W. Now my USB scope, has a dynamic range that is limited to -90/-100dB. Good for tube amps, but with the F5 all the harmonics are buried. Can I do the tuning at 10 W ?
Thanks,
D.
Thanks,
D.
use Cordell's distortion magnifier.
If that is not sufficient then consider a higher test frequency and/or a higher test voltage and/or a lower test load impedance.
If you still can't see it in any of the IMD tests then you probably can't hear it either.
- F5 power amplifier
