F5 power amplifier
I suggest bypass of the power supply caps.
regards
kp93300
I thought this is the key too... Now the last cap is small siemens sikorel,but i think good MKP should have positive influence,as i know allready, with these a-class transistor amps ANY mod in PSU are noticable.
I really hope that F5 can give suzuki superbike like performance with my titan dioxide tweeters,more "being there" felling.Now it's just amp that dont involve me much in the music.With harsh cd,speakers,maybe it would be very good.
Hi there,
Just built my first F5,standart PCB but with toshiba sk1530,sj201 transistors. 8x47000 caps,24V-1.1A.
First impression it's too smooth,like diy member Bear mentioned in "F5 listening" impressions" thread. But didn't find solution to solve this out.
Amps is very stable,with wide soundtage,great detail but too smooth at the top end,no simbiliance at all.
What could i do to improve resolution performance?
1.Bypass big electolytic caps with MKP?
2.Increase current to 1.3A?
3.Change Tosh's to IRFP's? (Teabag said tosh's smooth things)
4.Burn in amp ,since it's working only two hours or so?
5.Change resistors at PCB, meaning i have Toshiba instead IRFP?
There is no sibilance? that's good, not bad, unless you can measure a rolloff at HF.... 😀
_-_-bear
Hi everybody,
I'm in the first step to build a f5. I know that a lot of question have been made concerning heatsink. But I found some surplus stock of heatsink made for power rectifier on the web and I really don't know if they are ok for the project. The dimension is 6 1/4" X 6 1/4" X 9" Long.
Aluminum Heat Sink 6 1/4" X 6 1/4" X 9" Long. - eBay (item 7607693627 end time Apr-15-10 09:31:06 PDT)
Personally, I would not use these heatsinks because you will need a considerable distance between the PCB and the mosfets... the flat back with fins type extrusion is much easier to use with this type of amp.
There may be tricks to be able to make a flat attachment to the type of heatsink you showed, but they're not worth the effort, nor the machining especially for used ones with holes in them, or unless you have some cosmic styling aesthetic.
There are flat backed ones on ebay, someone mentioned the vendor earlier in this thread, iirc.
_-_-bear
I plan to make a vertical amp, the trafo and psu on the bottom and the heatsink on top with two channel pcb on the same surface. Is this heatsink fit for the job ?
Those heatsinks are commonly used, you'd need 4 of these I reckon.
The flat back heatsinks make a good base for the PCB.
The only problem i had was because the ehatsink had fins on the other side was I had to tap all the holes for the output transistors and pcb.
Of course I missed a bit of swarf and punctured one of the insulators !
Luckily I checked with a meter first before powering it up.
It was my first time using a tap and of course I broke two before looking up that you need cutting oil for them to work OK.
_-_-bear
It's not good when there are too much or too little simbliliance 🙂 But in some recordindgs it must be.Now i have a feeling of some kind of rollof,but there isn't, when different amp is connected 🙂 Vocals ,instruments arent "very" sharp.
Ok i try do not bother with my subjective opinion,will bypass psu,some other upgrades and write my final subjective decision some day 🙂
we have a separate thread for listening impressions and discussions, fwiw... but most folks equate "sibilance" or similar effects with "highs"... I prefer to compare to natural sound, which tends to not have the same sort of "electronic" or mechanical sounding effect.
Otoh, I have heard the F5 vary all over the map in terms of "sound" depending on all sorts of rather minor seeming things. So, wazzup wit dat? 😀
_-_-bear
Just built my first F5,standard PCB but with toshiba sk1530,sj201
Markofka, can you you tell us more about your build? You used standard R values from NP's schematic? Jfet's are 2sk170/2sj74?
I may be wrong, but you are the first to post about a build of the F5 using the Toshiba outputs in a stock (original NP F5 schematic) configuration.
LOL...I had no cutting oil when I tapped mine...ended up using extra virgin olive oil...worked great!😎
The absolute best lube for tapping aluminum I have ever used is Anchorlube
You won't believe how easy the tap goes through, first time you use it you will wonder if you drilled the hole too big.
And someone is selling it on E-bay so it is easy to get.
eBay.com.sg: ANCHORLUBE TAP CUTTING FLUID G-771 ECOFRIENDLY 4 FL OZ (item 220540873893 end time Apr 06, 2010 00:38:57 SGT)
I've been running F5 for close to 4 months every day, the sound has change several times over that period and only in last month has it good to where id called burnt in, during that period I've tried different types of speaker cable and interconnects, so if you want sibilance go to QED silver Anniversary's, once its burnt in I think you will find Ant-cables work best. You could put some 8 - 10 ohm resistors in place of speakers and let it run 24/7. But leave it 2 or 3 months before final adjustments.
and Thank you Nelson, and my neighbours thank you, Music Reference valve pre, 91db Tannoys, means plenty of volume. thanks to all contributors as well.
Listening to this approach of F5, I agree with Tee-bag's description:
92d1263914902-first-f5-without-current-limiting-thermistors-f5-no-tempco-no-current-limit-toshiba_tea_bag.jpg
http://www.diyaudio.com/forums/blog...-current-limiting-thermistors.html#comment387
I havent yet heard the F5, but I doubt very much it would lack resolution
I trust it enough to blame the speakers
Well, I probably would in almost any case....speakers are mostly the problem
Anyway, I usually need some time to get accustomed to new gear
Goes for anything, a different car, new bike, etc
A new stove may take up to a year 😀
Lets talk again in a year, and you might say the opposite
The sound of the F5 can vary all over the map.
NP already said that the bias setting alone will change things.
The brand of resistors seems to change it.
I have heard the very same amp go from stunningly clean and clear to rather fat, recessed and somewhat dull... just some seemingly minor changes made that happen!
Break-in? Roll the dice.
_-_-bear
@prooptiki: Thank you! That is just what I have been looking for.
I am building my first F5 exactly to the masters original design (updated w/22K current limiters) with IRFP240/FQA12P20, but I have a set of Toshibas for a second set of monoblocks. I was not going to use them unless a saw some well-explained mods to the original circuit, or, a revised schematic. Prooptiki's schematic matches my notes for the most part. I plain to do direct A/B comparisons when finished.
Anyone else have experience/comments on prooptiki's Toshiba implementation?
From my notes:
I use Toshiba outputs, sound wonderful, and w/o tempco they are very DC stable.
I think they are a bit more detailed than Nationals, while not sounding peaky or rough.
They are smooth and refined. I use .47r, but lowered R3 and R4 to 1K to get a little more
'action' out of the 5K pot. They otherwise bias up very quickly.
As posted here ages ago, my preferred configuration is Toshiba 2SK1530 / 2SJ201, balanced,
2A bias, 0R22 source resistors. I like Toshibas better than Fairchilds, but I am known to be biased.
> Am I right in thinking that we'd need to see ~2.7V across R3/R4 (instead of the 4.2V for
the IR or Fairchild parts) in order to bias the Toshibas to 1.3A?
Yes, so you need to adapt the circuit (e.g. lower bias for the JFETs).
I used 6mA Idss, which are unfortunately not easy to get. You can of course also lower the resistor value
at the drain of the JFETs.
i only reduced the trimmer value and got 2,7 volts for 2sk1530/j201..and everything is allright..
i didnt change anything other..
I got these Wild Burro 8" fullrange and my plan is to mate them with a 35mm TB, in a floor based omni design
In my experimental setup the small TB sounds pretty good, with lots of resolution, when carefully adjusted
When I get around to build my F5 I will know if its a good match
Maybe next year 😀
I would also like to share that in my set up , the addition of a pre transforms the sound for lethargic, lacking drive to' being there " with the musician experience . The treble in my ribbon tweeter is very detail and precise . The varying force of the drummer on the hat could be appreciated.
kp93300
The sound of the F5 can vary all over the map. NP already said that the bias setting alone will change things.
Bias is important, but also the F5 depends on a specific "sweet
spot" or nulling effect where the positive and negative halves
are just right. It takes a distortion analyzer to find it quickly
or a very good ear to find it slowly. Go off the balance and it
fattens right up, and some like that.
Personally I find it to be partly a function of the loudspeaker
driver. With something like the Feastrex D9nf, a little fat
doesn't hurt, or you can switch to an F3, or perhaps a nice
glass of cabernet.
