Hi All
I've got CViller F5 Boards (V1.0) mostly populated + PSU (V1.0) unpopulated with key parts.
All resistors on F5 boards have been matched and selected before soldering.
You'll have 2 matched MOSFets sets : Toshiba IRFP and Fairchild FQA.
Both sets are closely matched by reliables and trusted DIY sources.
Fairchild set is from EUVL, thread is here : http://www.diyaudio.com/forums/grou...hed-sets-fqa12p20-fqa19n20c-f5-power-amp.html
Matched JFets sets 2SK170/2SJ74-BL were sourced from Spencer.
Informations about CViller boards :
http://www.diyaudio.com/forums/group-buys/134554-gb-f5-pcb.html
As shown in pics you'll have the following parts :
1° - 2 x F5 CViller V1.0 boards populated with
Vishay Dale RN60D resistors - 0.47R Panasonic 3W/5% - 50R Dale RS10 10W/1%
Zetex 450/550 - Vishay Metal Film Resistors for R21/22 0.5W/1%
Unsoldered MOSFets, JFets, Thermistors and power Led are delivered.
You just have to find RLed
2° - 2 x EUVL FQA19N20 (3.76) + FQA12P20 (5.89) Matched MOSFet sets = SOLD
3° - 2 x HCFR IRFP240 (4.10) + IRFP9240 (4.06) Matched MOSFet Sets
4° - 2 x SPENCER 2SJ74BL+2SK170BL Matched JFet
5° - 4 x Keratherm Kerafold thermal pads for MOSFets
6° - 4 x Epcos NTC Thermistors 4K7 3986K (not soldered)
7° - 1 x Bridge Recitifer KBPC3506 35A/600V (brand new)
8° - (5+4) x 0.47R/3&4W Resistors for PSU
9° - 2 x 2.2K/3W Resistor for PSU
10°- 1 x On/Off 250V/16A switch + 1 fuse Holder (2.5mm stdt fuses) + 2 x Gold Plated RCA
11°- 1 x CViller PSU PCB V1.0 (unpopulated) + 2 x cristal Blue Led (not shown)
I could also supply caps for the PSU and heatsinks.
PM me for details and informations.
Phil
Phil
Hi Antonio
This is the Original version devellopped by CViller according to Nelson PASS FW design.
I haven't followed the "Official F5" thread, BTW I can't comment much more about the differences...
There are suited to be feeded by 2 Mosfets per chanel (1 Pos IRFP9240 + 1 Neg IRFP240).
Latest devs provides more power and BTW more heat
Phil
Phil
