Hi all,
Im building right now two stereo F5 power amps. I was thinking to try to bridge them as mono blocks (balanced mode), to get more power. Is there any issues I should think about either than the heat dispersion?
Im thankful for all tips and advise.
Thanks!
Thanks!
Thanks for you answer. However shouldnt it be possible to use them down to 4 Ohms, since the original F5 is stable to 2 Ohms?
i would not try to run it full out in class A even at 8ohm. unless your not using multiple outputs. 2.5A*23V=57.5W dissipation. so 2 pair of outputs pr half of the amp.
then you have a 100W class A monoblock.
so, why not just build F5turbo v3? what are Your goal with this amps?
Im building two stereo amps for me and a friend so I will have two amps on my hand for a while. I just want to try if it works if I want/need to have more power. The loudspeakers I have now is about 91 dB sensitivity and 6 Ohms (4 ohms min). Im not sure I will be enough with the stereo amp.
i run my F5 on 6ohm 90db speakers. but i have 1.7A bias insted of 1.3A. i also have 2 output pairs. rail voltage is +/-23V as original that gives me 35W class A at 6ohm.
- F5 in balanced mode?
