Hello,
Just won a pair of ESL 57s on eBay and now thinking about a suitable amplifier. Will the F5 do the job? If not, any other Pass amps better suited?
Thanks,
Brian
Thanks,
Brian
Not really knowledgeable in Pass amps, but what are the min ohms and sensitivity of the ESL 57s; and what SPL are you seeking . .
I believe the Aleph J would be ok. Boards from Peter Daniel.
Check this guys website.
DIY Audio Projects
DIY Audio Projects
ESL 57 Impedance
The impedance ranges from 60 ohms in the bass region to 1.8 ohms in the treble region. They can be driven well from 15-25 watts of amplifier power, but the amplifier must be stable into a low impedance at high frequency. Does that describe the F5?
Brian
Brian
I've used the F5 with my quads - sounds great, no bother to it driving them. But the F5 was not happy driving them stacked (wired in parallel).
But fire ahead with the F5.....
"This amp just seemed to love the quads"
The Naksa Amplifier | TírNaHiFi.org
Just don't turn up the wick; and save on summer cooling 😉
Why F5?
Why F5? Because higher powered amps can cause arcing and the 25 watt rating of the F5 seemed just right. Two amps from long ago that have the reputation of a good fit with the ESL 57s are the Bedini 25/25 and the Mark Levlinson ML-20 - both in the same power range. So if the F5 does the job with the difficult load, it would be ideal (and I already have Peter Daniel's F5 boards).
Brian
Brian
Yes- that was me that wrote that review - and I had both the Naksa and the F5 together at the same time. The Naksa is really very very good. Its a pre-built kit so the initial cost is a bit more, but all you need do is add Tx and connectors.
Hugh is also involved in this amp: http://www.diyaudio.com/forums/aksa/191053-swordfishy-aspen-fetzilla-power-amp.html
I'd bet it would sound good too......
F5 though is a nice build and will suit a lot of speakers.
Fran
Fran
Costs aside, for Quads, which would you prefer . .
hazarding a guess?:
For bass & mids lovers: the NAKSA
For mids & treble lovers: the F5
hazarding a guess?:
Oooh would be very hard to choose. Both sound different but very good. The higher power rating of the naksa might make it more compatible with more speakers but I've used the F5 with a good few speakers and it always sounds excellent. First time it suffered was with the stacked 57s. Treble went harsh and I also took out a few source resistors. Probably due to some kind of oscillation with the load?
Anyway both sound great. Note that the F5 throws out a fair bit of heat, but the naksa runs barely warm.
Does the naksa with a good few speakers also sound excellent?
thanks (and sorry for off topic/ topic expanding)
Honestly I can't say because I've only heard it with a couple - but I would think so. Check out the info in the aksa forum.....
How about the Quad 303? Cheap and good and plentiful.
I would suggest you look for amps designed to go with the ESL 57, some can be had for very reasonable prices.
The Quad 303 and the ESL 57 are a special combination not to be over looked on price and practicality grounds. Leak 30 series amplifiers are a good cheap option, and Sugden also design their amplifiers for the Quad speakers, I think Sugden stuff is higher quality sound than Quad Amplifiers which are more ergonomic than the fiddly Sugden. JLH Class A amplifier I had as a student sounded wonderful with them best option in my opinion, though I never finished the project amplifier project due to money. Higher powered amps are often a very bad combination with the ESL 57, apart from fear of damage they often sound distorted. As an atypical example I would recommend against the Quad 405, which fails in a similar but different way from other amplifiers of higher or similar power range with the ESL 57's. Remember that amplifiers specifically designed for the ESL 57 such as the Sugden A21 will need their capacitors completely replaced, even 1980's kit will. This will likely cost 70-80 Euro at a web retail supplier to replace an amp with similar sized power supply and speaker decoupling capacitors. You may well up the values of some components in older designs, extra capacitors in the 303 is nice to have for Bass performance.
You could alternatively go the output transformer approach of valve amplifiers. Valve amplifiers, and Macintosh solid state amplifiers use transformers to decouple the output impedances. Sugdens are Capacitor coupled , like the Quad 303, which provides some impedance decoupling but unfortunately like the transformer capacitors negatively effect low frequency response, when you have ESL 57's a pair of lovely full range Electrostatics this lower power delivery at low frequencies will in my opinion even play as an advantage.
If your amplifier is not well suited to the Quad ESL 57's which I assume is usually caused by current clipping, you might find putting a very small high power resistor in series with the amplifier, it will reduce sensitivity but avoid the amplifier current clipping, with that sharp impedance drop.
Owen
Owen
Brian
how confident are you that you can accept the compromises of the Quads, long term?
(I have a friend who cant, and is selling his)
Otto88 - what was bugging him about them?
From the about to be ex ESL 57 owner, specifically:
"dynamics, looks, amount of space used in the room.
about 1/2 of what i listen to is rock, and the QUADs sort of let me down on this stuff. intellectual instead of visceral"
- F5 & ESL 57
