F5 Build questions
hello - could i ask a few questions on the build of the F5 clone please
i have just soldered both the PSU and the boards. I am using DIYAudio bridge circuit.
1) i am having to split the two power supplies, in the build guide, grounds are connected by links but mine are on the left and right of the amp. Could i connect the PSU grounds 1,2,3,4,5 to the common point chassis ground?
2) What are the ST_1,2 on the board used for?
3) what is the difference between AUD Gnd and Gnd on the PSU board ? what do i use the AUD gnd for?
4) why do they have v-, v--, v--- etc?
5) same for ground 1,2,3,4..? are these all connected internally? if so, why are they connecting so many links between the grounds on the pcb?
Thank you very much
Philip
