some info in missing on your end. Do you plan to build it P2P, proto board, or do you have a ready made board. If you have a pre-made board, all you need to do is read Nelson's F5 article. Cviller's, and Peter Daniel boards, are exact copies of the schematics, and numbering system that Nelson uses. Cviller also has a .pdf file somewhere floating around that explains the buildup of his board, it's not really a step by step, but it helps.
1108 said:I plan on using ready made boards. I'm not sure what you mean by "Nelson's F5 artical". Where do I find that? I did find one artical on his website titled F5 Power Amplifier dated 1/31/08. Good information but not everything.
here is the F5 manual.
cviller's guide
cviller's group buy
and the original F5thread
jim
