you can put 22 of them in series
(or you can dismantle anything broken in your house , and find any cap between 680p and 3n3)
hehehehe😀😀 thats no good. i have only 3😀
i can have a look on a amp board i have here. but i think there are only 1uF and 4.7uF.
i found i found🙂 2.2nF 2 in parallel.
the common bias problem
Hi all
I'm also having the common bias problem:
I can get max 0.4V with 0 offset above that bias offset goes up.
All i have around are 4.75K resistors to change R3 & 4 ( from 2.2k)is that okay or is 4.75 too much resistance ? I would like to resolder resistors only once and get it right this time
Thank you everyone
ik
Hi all
Thank you everyone
ik
- F5 Bias Problem
