"F400" 400W PA with IRFP240/IRFP9240
Does anyone have a parts list for the attached schematic?
Here's its PCB:
Regards,
Ermac
P.s.
Can an output short circuit protection be added to this amplifier?
  • f400.pdf
FETs need a Zener from Gate to Source to prevent excessive Vgs destroying the FET.
This Zener (Zd3 & Zd4) can be reduced in voltage using the graphs in the datasheet to achieve short circuit protection. Add a diode in series with each of Zd3 & 4.
In other words, do some reading and you will find that the protection you are asking for costs nothing. A version is already be there.
