F4 Channel Problem - Running Cold
The Nichicon FM series are very magnetic and now you tripped a breaker in my head.
The Silmic II are not magnet.
I'm going with Nichicon Muse UFG. None of the Nichicon classes list whether or not they are non-magnetic. Only the Silmic II notes mention tinned copper leads.
I'm tired of looking, so Muse will have to do.
Woosies :rofl:
there is nothing wrong with little Iron in circuit....... so why excluding resistor & cap leggies from that ?
:clown:
btw. I had a dream , how to manage that situation with one channel weak;
just move it to place of proper channel , and it'll heal
:rofl:
(not going to say that it worked for me in my repair boozines ..... but never late to try ......... again )
Replaced all caps, ran fine until plugged into the system, then went cold. Replaced bias pot and TL431 and ran ok until I brought up the AC voltage to 120v.
So this change of parts worked out worse then just replacing the caps.
Unless anyone has a suggestion, I'll buy new boards and matched mosfets from the store.
Replaced both pots as well
I don't understand why it works a little while then the bias just drops.
At this point it's faster for me to build a new board.
Maybe I'll just remove each part and check off board.
Look at it as a project in itself.
