F3 pcb group buy...
Assembled boards
I almost finished soldering my boards (still missing a few resistors) and wanted to share with you a picture of them.
hc167 said:
oh, nice picture. Is the Jensen 4-poles capacitors suppose to use to power supply filter???
Thank you. I am not an expert but people on this board have used the Jensen 4-poles capacitors for the output cap and reported positive results. Also, Peter Daniel has used these capacitors in his ZV9 amp. Maybe Peter can provide his opinion.
Could you clarify how the Jensen 4-pole should be connected if used on the amp board? Do you have to cut traces to have it done correctly? If so, which ones? I know Peter marked the F4 power supply boards, but not clear exactly how to do it for the amp capacitor.
