Hi Peter
I wanted to add a F5 amp and F% PS card to my prior order.
Also adding another thanks for your effort on this.
Stroob
Stroob
F1 boards
this out, all you transconductance freaks. An F1 group buy is in the works. To help you round out your firstwatt amp collection.
http://www.diyaudio.com/wiki/index.php?page=F1
vonfilm said:I just sent $60.00 by paypal for 2 F5 Amp boards and 2 F5 PS boards. I recently ordered F3 and F4 amp boards and PS.
Please consider doing the F1 and F2 also. I would like to have the complete set.😀
I just put my name on the wili for the F1 boards.
If Peter could do an F2, then all the F amps would be available now.
F2
I built a perfboard F2.
My recommendation for pcb power resistors would be to use Caddock MP's and heatsink mount them. It would tidy up the board size a bit, and sink more of that tremendous amount of heat off those 1 ohm resistors into a heatsink.
Peter Daniel said:Sure you can start Wiki; if there is a need for 50pcs or so , I can do that.
Will you maintain same spacing across fets a la F4?
If so, I'm interested 😱
Vale
Peter Daniel said:Of course it would be same spacing, so you can swap boards.
Very cool. thanks!
Vale
Peter,
Which of your PS boards will work for F2? I assume that I will need 1 PS board?
For DW8083' F1 Board GB, which of your PS boards is suitable? Would I need 1 or 2 PS boards for this?
Both F1 and F2 would be using F3 PS board. You need one board per amp, if you want to use more capacitance, use one per channel (to parallel caps)
F3 and F5 PCB Boards
Peter, put me down for (1) F3 PS PCB and a pair of F3 amp boards, and (1) F5 PS PCB and a pair of F5 amp boards. I am thinking of bi-amping......
hi Peter
I sent my payment for the 2 PS and 2 F4 boards. Thanks
I used the wife's paypal account hence the different first name.
Jan
Jan
Re: F3 and F5 PCB Boards
F3/f4 payment info was posted here: http://www.diyaudio.com/forums/showthread.php?s=&postid= post1680605#post1680605
F5 orders: hhttp://www.diyaudio.com/forums/showthread.php?s=&postid= post1684087#post1684087
Payment received, thanks.
dcbingaman said:Peter, put me down for (1) F3 PS PCB and a pair of F3 amp boards, and (1) F5 PS PCB and a pair of F5 amp boards. I am thinking of bi-amping......
scranton said:I sent my payment for the 2 PS and 2 F4 boards.
Nothing really, just make another payment with a note that you are adding to your original order.
Peter,
From the sounds of that last post, you are sending a confirmation email for each payment?
Mine was sent 9-dec-8
dave
dave
- Group Buys
- F3 and F4 Clone PCB Reissue group buy, also F5 PCBs
